www.thingiverse.com
Servo Hinge for Iron Man Helmet by ByteSlingerThis is a servo hinge setup for use with MIPRESIDENT's Iron Man Mark III helmet (http://www.thingiverse.com/thing:260152).
You can see my final build here: http://www.thingiverse.com/make:286759
And a video of it in use here: https://youtu.be/q4N2HxEN5ng
You can follow me as I print and build the full suit on my channel here: https://youtu.be/aBibldoc0sg
This hinge setup requires no modification of the existing model and doesn't involve drilling/screwing through the sides.
You will need to print:
1x Face Mount
1x Flat Top
1x Hinge Arm
1x Hinge Brackets
1x Second Hinge
1x Second Hinge Mount
1x Servo Mounts
2x Small Arms
1x Hinge Limiter (Optional)
1/2x Small Arm V2 (Optional)
For this you will also require:
1x MG995 servo
1x servo micro controller (eg. Arduino Nano)
11x M4x10 Bolts
7/14 M4 Washers
Extreme hold adhesive (Loctite 401 is an ideal adhesive for plastic to plastic, including PLA)
I hope you enjoy printing and using my design. To help me keep designing and uploading more things, as well as continue to run my YouTube channel (http://www.youtube.com/c/3drevolution), please consider making a small donation to me via PayPal: http://www.paypal.me/JoshForwood
Thank you!
Wow! This helmet looks so cool. Thanks for sharing it and geometry dash lite which is intriguing.
I recommend also to share this video in social networks. For example to share your YouTube video on Instagram, first, download the video to your device. Then, open Instagram, go to your profile, and tap the '+' button to create a new post. Choose the downloaded video and edit as needed. Ensure the video meets Instagram's duration and size limits. Post the video on your feed or stories. However, sharing content on Instagram requires strategy. Learn effective methods by exploring resources like Jesusmanifesto's guide(look here) on getting more Instagram likes. Understanding Instagram's algorithms and audience engagement is crucial for successful content promotion. Follow best practices to enhance your reach and impact.
Instagram @thehlshow
