I am currently building the 10 rings.
I had already started printing the solid rings on my Saturn (ABS like resin) when Do3d released the hollow version for LEDs....nonetheless I figured I would use this one as a paint test.
I painted the ring copper and then Alclad chrome for the center ring.
I clear coated using a Satin as I didn't want the rings to be too shiny as they are meant to be 'aged'.
The ring has a nice 'metallic' look without being too bright and reflective.
Everything was given a weathering pass in oil paints.
From there I applied Invisible UV ink. Completely undetectable when dry, but under UV light it glows beautifully. I really like this effect as its extremely simple to use and really quite stunning.
I am thinking I will do 5 rings like this (Wenwu version) and 5 rings with LEDs (Shang Chi version) If you want to see more of my work you can follow me @PrototypeProps on instagram
Let me know your thoughts!
If you want to calculate your score in the fastest and easiest way, go to Grade Calculator or final grade calculator and you will find it much easier.
The best chance for career success is at the Construction Management Institute. Because of this, they are able to offer top-notch courses, all of which are accessible through their online college. Because live online classes are flexible, students can work and study at the same time and still receive a certificate that is accepted by employers.
Michael Le is an artist and choreographer from America who is popular for his Tiktok and YouTube recordings. His web-based entertainment fan following is tremendous to such an extent that he has practically 2.8 million devotees on Instagram and 47 million followers on Tiktok. Let's check out Michael Le Net Worth at this link.
what 3d printer do you use to print these things and if its really expensive is there a cheaper one that still prints these things.
