Let’s explore why Do3D made bonus wings (longer horns) for the Wolverine D3 Helmet. The shorter ones on the left are the original wings. We developed the longer versions on the right in response to requests from some users.
Many references of wings appear to have longer wings than those on the left in our image, likely due to their downward angle.
When you rotate it downwards, you'll notice that it appears longer and nearly matches the length of the longer wings we recently created.
Let's take a look at this from the front view once more.
As you can see, simply rotating the shorter wings downward makes them appear almost as long as the extra-extended wings on the right. We created much longer wings on the right so users can achieve the same look without needing to put their chin down. However, please note that the design on the left is the correct one, matching the official references for both front and side views.
Other notes:
This helmet uses 8 x 2 mm round magnets https://amzn.to/3VrgFA2
Here is the list of 3D printers and supplies we frequently use: https://www.do3d.com/post/what-3d-printers-and-essential-supplies-does-do3d-recommand.
License (personal): Please contact us at info@do3d.com for additional licensing options.
🌟 Make sure you're connected with us on all social platforms! We've got some great surprises coming up for each channel in the weeks ahead. Stay tuned!
Thank you very much for your amazing support!
Im with everyone else, where do we get the update if we bought the older one?
where can i find the old model
Se podrÃa hacer una actualización con el diseño que sacó hot toys?
It is worth noting that the old wings do not fit with the new helmet and vice versa. I was printing the older model when this came out and I used the newer wings, not the longer one and it doesn't fit. I instead reprinted the whole new helmet. It was so worth it
I bought the files and we are wondering how to get the update?
Hey Do3D! I bought the original wolverine helmet and I'm not sure how to access the new updated files. I haven't received any emails from you guys with the new files so please get back to me as soon as possible! Thank you
