Hi All,
I've been printing with CR10's for a few years now, so here's some tricks and tips, of course these are just my opinions so don't treat them as gospel ;)
Hot End Fan / Heat Creep
Ok a common issue with CR10's is heat creep, this is where the filament melts before the nozzle and you'll get crap layers and eventually a total block, one of the main reasons for this on the cr10 is the hot end fans they use, they are total junk
Replace this fan ASAP, don't be temped to go for an expensive ultra quiet fan, you need to check the m3 of airflow, example a lot of people choose the noctua fan, but cheking the spec sheet reveals
its 8.2m3 of airflow, the stock fan is 12m3 ! so this fan won't cure your problem!! get a fan with AT LEAST 12m3
Card Slot
Another common issue is the TF card slot, they are delicate and very easy to break, your first purchase should be an SD card extension, this will save you TF slot and is just much easier to swap cards
Filament
ok, so you're up and running, and you've gone out and bought 10 rolls of multicoloured filament! but each one prints terribly??? whats going on??
Every make of filament is different, even different colours from the same brand are different, you could be printing black pla perfectly, then switch to white on the same brand and its terrible, you've tried calibrating your estep but still its rubbish
How to calibrate your estep
https://letsprint3d.net/how-to-calibrate-the-extruder-steps-ender-3-5-cr-10/
the reason for this is the density of the filament, different colours have different densities so will print totally differently, heres a guide on tuning you're printer for individual filaments
https://e3d-online.dozuki.com/Guide/Flow+rate+(Extrusion+multiplier)+calibration+guide./89
the best advise I can give here is tune your printer for a specific brand and colour, I only use black PLA+ from specturm (unless I can't get it lol)
Cable Management
The cable management on the CR10's isn't great, especially on the CR10 s5, I'd suggest you get extension cables (a must if you're using big rolls of filament), but then you have another issue, the cables can (and will) hit the print, a simple solution, that actually works, is one of those elastic badge holders ;)
Heated Bed and PLA
Basically if you're printing with PLA in normal temperatures (so you don't live in the north pole) you don't need to turn on the heated bed, use decent filament and it won't warp (lots of people will disagree with me here, what can I say?? its not turned on and its all good)
Prints won't stick to bed
This old chestnut!, you've leveled your bed, yet they still won't stick!! I won't go into leveling the bed here, unless people really want me to? but once you have leveled it as per the millions of youtube videos out there, put a bit of blu tack (kids putty type stuff, google it) between each leveling wheel and the bed to stop them moving, also make sure the bed isn't wobbling, if you've had to move knobs a lot then the springs aren't tensioned enough, you'll need to add more washers under the spring.
I've read lots of weird and wonderful things people use to make prints stick, really weird things!! but this is all you need
3DLAC, job done
I want to print BIG things, but keep running out of filament!
trying to print a whole ironman chest in one go but the filament runs out in the middle of the night!!! the simple solution is use bigger rolls! you'll need to do a couple of things first,
Upgrade your extruder! the stock extruder is no where near man enough to pull >1kg rolls so go all metal
I'd recommend this one
don't be temped by the $3 aliexpress ones, you get what you pay for, and losing a 3 day print because your cheap extruder has failed would have cost you more then buying this one ;)
next you'll need a bearing filament holder, fortunately thingivese has loads of them https://www.thingiverse.com/ you'll need to get hold of some bearings of course, most use escooter / skate board bearings which are cheap and easy to get hold of, heres one of mine, 4.5kg roll - note you will need extension cables to stop the roll hitting the printer frame!
Spare Parts
Get some! nothing worse then having a printer down for weeks while you're waiting for parts, get spare nozzles, thermistors, heater cartridge, boden tube and the boden tube fittings, they are cheap and consumables, the creality web store delivery pretty quickly but loads of sellers of this standard stuff on aliexpress
Replacement Hotends / direct drive
Another hot topic! I've used microswiss hotends on all my printers for a couple of years, they are infinitely better then stock, but, you need to make sure you've replaced your hot end fan to something decent, and you need to reduce your retraction setting, otherwise you'll clog.
DO NOT be temped to get those cheap clone microswiss of ebay / aliexpress - I've tried them all and they are all total junk
On 2 of my printers I've moved to Bondtech direct drive units, yes they are very expensive, but wow!! they just don't clog, you can print hotter and faster (direct drive basically puts the extruder next to the hot end, no boden tube needed) they took a little bit of messing to get working but once you're up and running those 10 day prints are nothing to worry about
India has emerged as a prominent hub for WordPress web development services, offering businesses and individuals a cost-effective and high-quality solution for creating and maintaining their online presence. With a vast pool of skilled and experienced WordPress developers, India has established itself as a preferred destination for businesses seeking to leverage the power of WordPress for their online endeavors.
https://www.artattackk.com/wordpress-development-company-india/
You're welcome for sharing this. I agree with all of your points. I've (sadly) learnt all of these valuable lessons the hard way over the previous few years. This would have been a huge time-saver for me. geometry dash
Regards for publishing this. I concur with slime rancher 2 what you have said. All of these are excellent suggestions that I (unfortunately) had to learn the hard way over the previous few years.
Does the V2 have same issues?
I have just order the CR10 and every new at this. Thanks for the info.
Have you tried the Hemera?
does the Bondtech direct drive units come with instruction on how to fix to the cr-10s? thanks
Hey man! Killer guide! Really!
p.s. Fix your title haha 😂
Thanks for posting this. I second everything you said here. These are all great tips that I (unfortunately) learned the hard way over the past few years. This would have saved me a bunch of time.
I taught him everything he knows.
