Well, my work is still in progress, but I already have images of my new stormbreaker with the painting almost ready. (My first one was sold) I used the Do3d file, but made some modifications and the ax will still receive a set of leds. If you notice in the photos, you will see that there are some specific points that you can see the splice / division or even without a glue, I explain: I intend to put leds on the ax, so I can't finish it completely until I pass the wires assemble the circuit, but the painting is basically ready, missing only the varnish that is the last part after everything has been glued. The rear part I customized, the ax of the film doesn’t have Yggdrasil, but I thought it would give a special touch when it’s with the LEDs. There are still tbm to pass the strings on the cable, which although the new version does not have, but I will put it.
Edited: Sep 06, 2021
Thor Stormbreaker
Thor Stormbreaker
1 comment
1 Comment
But I thought it would give a special touch when it’s with the LEDs drift hunters
